Some of you have completed our Online Continuing Education Courses which include video instruction. For the rest of you we are sending a weekly series of newsletters featuring an instructional page complete with videos.
To view the videos you will need to download the free Real Player Download Real Player plugin for your browser - if you don't already have it. After installing Real Player, you can view the videos by clicking on one of these icons:
  • Click on this icon Hi Res - Cable/DSL [5622Kb] if you have a cable or DSL connection.
  • Click on this iconLow Res - Modem [1695Kb] if you have a Dial-up connection.
Below is the full course page which includes these videos:
Article 210 Low Res - Modem [1695Kb] Hi Res - Cable/DSL [5622Kb]        Page 3 of 11
Branch Circuits
210.7 Branch Circuit Receptacle Requirements
New text clarifies the requirement for simultaneously disconnecting the ungrounded branch circuit conductors.
(C) Multiple Branch Circuits. Where more than one branch circuit supplies more than one receptacle on the same yoke, a means at the branch circuit panelboard must be provided to simultaneously disconnect the ungrounded (hot) circuit conductors supplying the receptacles. Figure 210–1
Author’s Comment: Single-pole breakers with approved handle ties, or a multipole breaker (2 or 3-pole) can be used to simultaneously disconnect the ungrounded circuit conductors.
Intent: The intent is to require all ungrounded (hot) circuit conductors terminating on multiple receptacles (duplex) on the same yoke to be disconnected simultaneously regardless of type of occupancy. This rule is intended to prevent persons from unintentionally working on energized circuits that they thought were disconnected. The 1999 NEC only required the circuit disconnect to simultaneously interrupt the multiwire circuit to multiple receptacles on the same yoke if the receptacle was located in a dwelling unit.
Author’s Comment: It was not the intent of this rule to apply to multiwire branch circuits, because a multiwire branch circuit is considered as one circuit [100]. However, many will take the opportunity to apply this rule to multiwire circuits.
Figure 210–1
Click on Image to Enlarge
Copyright © 2003 Mike Holt Enterprises,Inc.
