Send to a Friend View / Add Comments
Some of you have completed our Online Continuing Education Courses which include video instruction. For the rest of you we are sending a weekly series of newsletters featuring an instructional page complete with videos.
To view the videos you will need to download the free Real Player Download Real Player plugin for your browser - if you don't already have it. After installing Real Player, you can view the videos by clicking on one of these icons:
  • Click on this icon Hi Res - Cable/DSL [5622Kb] if you have a cable or DSL connection.
  • Click on this iconLow Res - Modem [1695Kb] if you have a Dial-up connection.
Below is the full course page which includes these videos:
Article 240 Low Res - Modem [1695Kb] Hi Res - Cable/DSL [5622Kb]        Page 8 of 8
Overcurrent Protection
240.85 Applications
Author’s Comment: A 120/240V slash circuit breaker cannot be used on the high-leg of a solidly-grounded 120/240V delta system, because the phase-to-ground voltage of the high-leg is 208V, which exceeds the 120 line-to-ground voltage rating. Figure 240-6
FPN: Circuit breakers on systems other than on a solidly-grounded wye, particularly on corner-grounded delta systems, should consider the individual pole interrupting capability.
Author’s Comment: A slash rated breaker cannot be used on corner-grounded systems because phase-to-ground voltage is equal to the phase-to-phase voltage.
Intent: The change was the addition of the words “solidly grounded.” This was needed to emphasize that slash-rated devices were not appropriate on resistance-grounded and ungrounded systems.
Figure 240–6
Click on Image to Enlarge
  [ Back to Top ]
Copyright © 2003 Mike Holt Enterprises,Inc.
