Send to a Friend View / Add Comments
[ Reissued: Due to server problems last week very few people got this one ]
Some of you have completed our Online Continuing Education Courses which include video instruction. For the rest of you we are sending a weekly series of newsletters featuring an instructional page complete with videos.
To view the videos you will need to download the free Real Player Download Real Player plugin for your browser - if you don't already have it. After installing Real Player, you can view the videos by clicking on one of these icons:
  • Click on this icon Hi Res - Cable/DSL [5622Kb] if you have a cable or DSL connection.
  • Click on this iconLow Res - Modem [1695Kb] if you have a Dial-up connection.
Below is the full course page which includes these videos:
Article 250 Low Res - Modem [1695Kb] Hi Res - Cable/DSL [5622Kb]        Page 1 of 6
General
250.2 Definitions
The following definitions were added to Article 250:
Effective Ground-Fault Current Path. An intentionally constructed, permanent, low-impedance path designed and intended to carry fault current from the point of a line-to-case fault on a wiring system to the grounded (neutral) at the electrical supply source, see 250.4(A)(5). Figure 250–1
Author’s Comment: An effective ground-fault current path is created when all electrically conductive materials that are likely to be energized are bonded together and to the grounded (neutral) at the electrical supply. Effective bonding is accomplished through the use of equipment grounding conductors, bonding jumpers, metallic raceways, connectors and couplings, metallic sheathed cable and cable fittings, and other approved devices recognized for the purpose. A ground-fault path is effective when it is properly sized so that it will safely carry the maximum ground-fault current likely to be imposed on it.
Intent: The addition of these definitions will be very helpful for the Code user to understand the performance requirements contained in Article 250. Defining the words or terms will help the users more readily understand the requirements of Article 250.
Ground-Fault. A ground-fault is an unintentional electrical connection between an ungrounded (hot) conductor and metal enclosures, raceways, equipment, or earth. Figure 250-2
Ground-Fault Current Path. An electrically conductive path from the point of a line-to-case fault on a wiring system through conductors, equipment, or the earth extending to the grounded (neutral) terminal at the electrical supply source.
FPN: The ground-fault current paths could consist of equipment grounding conductors, metallic raceways, metallic cable sheaths, electrical equipment, and other electrically conductive material such as metallic water and gas piping, steel framing members, stucco mesh, metal ducting, reinforcing steel, shields of communications cables, or the earth itself.
Author’s Comment: These definitions originated from the Usability Task Group recommendations for clearly describing what grounding and bonding is intended to accomplish.
Figure 250–1
Click on Image to Enlarge
Figure 250–2
  [ Back to Top ]
Copyright © 2003 Mike Holt Enterprises,Inc.
