Send to a Friend View / Add Comments
Some of you have completed our Online Continuing Education Courses which include video instruction. For the rest of you we are sending a weekly series of newsletters featuring an instructional page complete with videos.
To view the videos you will need to download the free Real Player Download Real Player plugin for your browser - if you don't already have it. After installing Real Player, you can view the videos by clicking on one of these icons:
  • Click on this icon Hi Res - Cable/DSL [5622Kb] if you have a cable or DSL connection.
  • Click on this iconLow Res - Modem [1695Kb] if you have a Dial-up connection.
Below is the full course page which includes these videos:
Article 250 Low Res - Modem [1695Kb] Hi Res - Cable/DSL [5622Kb]        Page 6 of 6
General
250.4 General Requirements for Grounding and Bonding
(A) Grounded Systems.
(5) Effective Ground-Fault Current Path. Electrical equipment and other electrically conductive material likely to become energized must be installed in a manner that creates a permanent, low-impedance circuit capable of safely carrying the maximum ground-fault current likely to be imposed on it from where a ground-fault may occur to the grounded (neutral) terminal at the electrical supply source, see definition 250.2
The earth cannot be used as the sole equipment grounding conductor or effective ground-fault current path. Figure 250–7
Intent: The changes to this section should make it much easier to understand the grounding and bonding requirements contained in Article 250. The most significant change includes the explanation that, in order to clear a fault, the fault current must have an effective low-impedance ground-fault current path back to the grounded (neutral) terminal at the power supply.
Figure 250–7
Click on Image to Enlarge
  [ Back to Top ]
Copyright © 2003 Mike Holt Enterprises,Inc.
