Send to a Friend View / Add Comments
Some of you have completed our Online Continuing Education Courses which include video instruction. For the rest of you we are sending a weekly series of newsletters featuring an instructional page complete with videos.
To view the videos you will need to download the free Real Player Download Real Player plugin for your browser - if you don't already have it. After installing Real Player, you can view the videos by clicking on one of these icons:
  • Click on this icon Hi Res - Cable/DSL if you have a cable or DSL connection.
  • Click on this iconLow Res if you have a Dial-up connection.
Below is the full course page which includes these videos:
Article 400 Low Res - Modem Hi Res - Cable/DSL        Page 4 of 4
Flexible Cords and Cables
400.8 Uses Not Permitted
This subsection was revised to read:
Unless specifically permitted in 400.7, flexible cords and cables cannot be used for the following:
(1) As a substitute for the fixed wiring of a structure
(2) Where run through holes in walls, structural ceilings, suspended ceilings, dropped ceilings, or floors
(3) Where run through doorways, windows, or similar openings
(4) Where attached to building surfaces
(5) Where concealed by walls, floors or ceilings, or located above suspended or dropped ceilings.
Figure 400–2
(6) Where installed in raceways, except as otherwise permitted in this Code
Intent: The change clarifies that flexible cords cannot be located above a suspended ceiling. However, wiring within a raised floor is permitted, because this space is not considered a concealed space.
Figure 400-2
Click on Image to Enlarge
Copyright © 2003 Mike Holt Enterprises,Inc.
