Send to a Friend View / Add Comments
Some of you have completed our Online Continuing Education Courses which include video instruction. For the rest of you we are sending a weekly series of newsletters featuring an instructional page complete with videos.
To view the videos you will need to download the free Real Player Download Real Player plugin for your browser - if you don't already have it. After installing Real Player, you can view the videos by clicking on one of these icons:
  • Click on this icon Hi Res - Cable/DSL if you have a cable or DSL connection.
  • Click on this iconLow Res - Modem if you have a Dial-up connection.
Below is the full course page which includes these videos:
Article 406 Low Res - Modem Hi Res - Cable/DSL        Page 4 of 4
Receptacle, Cord Connectors, and Attachment Plugs
406.8 Receptacles in Damp or Wet Locations
Parts of this section were revised to read:
(B) Wet Locations
(2) Other Receptacles.
All other receptacles installed in a wet location must comply with (a) or (b):
(a) A receptacle installed in a wet location must have raintight while-in-use cover (enclosure that is weatherproof with the attachment plug cap inserted) if stationary or fixed equipment is plugged into it.
(b) A receptacle installed in a wet location having a weather resistant cover (cover that is weatherproof when the cover is closed and an attachment plug is not inserted) is permitted, if portable equipment is plugged. Figure 406-3
Figure 406-3
Click on Image to Enlarge
Copyright © 2004 Mike Holt Enterprises,Inc.
