Send to a Friend View / Add Comments
Some of you have completed our Online Continuing Education Courses which include video instruction. For the rest of you we are sending a weekly series of newsletters featuring an instructional page complete with videos.
To view the videos you will need to download the free Real Player Download Real Player plugin for your browser - if you don't already have it. After installing Real Player, you can view the videos by clicking on one of these icons:
  • Click on this icon Hi Res - Cable/DSL if you have a cable or DSL connection.
  • Click on this iconLow Res - Modem if you have a Dial-up connection.
Below is the full course page which includes these videos:
Article 525 Low Res - Modem Hi Res - Cable/DSL        Page 2 of 2
Carnivals, Circuses, Fairs, and Similar Events
525.32 Grounding Conductor Continuity Assurance
A new requirement was added to require testing of the equipment grounding conductor. This new section reads:
The continuity of the grounding conductor system used to reduce electrical shock hazards as required by 406.3(C) [Receptacles - Methods of Grounding], 250.114 [Equipment Grounding - Equipment connected by Cord and Plug], 250.138 [Methods of Equipment Grounding - Cord-and-plug-connected Equipment], and 527.4(D) [Temporary Wiring -Receptacles] must be verified each time the portable electrical equipment is connected. Figure 525-1
Intent: Testing of the equipment grounding conductor is required to ensure a greater level of electrical safety at carnivals, circuses, or fairs.
Author’s Comment: This requirement seems vague to me because it does not specify how the grounding conductor must be tested, what circuits are required to be tested, and who is required to do the testing.
Figure 525-1
Click on Image to Enlarge
Copyright © 2004 Mike Holt Enterprises,Inc.
