Send to a Friend View / Add Comments
Some of you have completed our Online Continuing Education Courses which include video instruction and know this is a very fast way to obtain your CEU credits from the comfort of the chair you're sitting in. For the rest of you we are sending a weekly series of newsletters featuring an instructional page complete with videos.
To view the videos you will need to download the free Real Player Download Real Player plugin for your browser - if you don't already have it. After installing Real Player, you can view the videos by clicking on one of these icons:
  • Click on this icon Hi Res - Cable/DSL if you have a cable or DSL connection.
  • Click on this iconLow Res - Modem if you have a Dial-up connection.
Below is the full course page which includes these videos:
2002 Changes to the NEC®
Article 680 Low Res - Modem Hi Res - Cable/DSL        Page 6 of 10
Swimming Pools, Fountains, And Similar Installations
680.22 Area Lighting, Receptacles, and Equipment
A new item (4) was added and it reads:
(A) Receptacles
(4) Restricted Space.
One 15 or 20A, single-phase, 125V receptacle can be installed not less than 5 ft. measured horizontally from the inside wall of the pool at a dwelling unit, if the dimensions of the lot does not allow the receptacle outlet required in 680-22(A)(3) to be 10 ft. from the water. Figure 680–4
Intent: The new rule allows the required 15 or 20A, single-phase, 125V receptacle for outdoor pools and spas for dwelling units [680-22(A)(3)] to be located less than 10 ft., but not closer than 5 ft., from the pool, if the dimensions of the property prevent locating the receptacle 10 ft. away as required in 680.22(A)(3).
Figure 680-4
Click on Image to Enlarge
2002 NEC Changes Course - Part 2, Article 338 - Ch.9
This code changes program covers the changes to Article 338 through Chapter 9 of the 2002 NEC. Included is a video of one of Mike's most dynamic live classes with a fully illustrated, full-color textbook. The textbook contains over 150 diagrams which make the changes easy to understand. Includes textbook and 4.5-hr video.
Product Code: 02CCV2
MultiMedia: VHS Tape
NOTE: This course is also available in DVD format. Click here for details.
Table of Contents
Sample Pages
Sample Graphic
Copyright © 2004 Mike Holt Enterprises,Inc.
