Send to a Friend View / Add Comments
Some of you have completed our Online Continuing Education Courses which include video instruction and know this is a very fast way to obtain your CEU credits from the comfort of the chair you're sitting in. For the rest of you we are sending a weekly series of newsletters featuring an instructional page complete with videos.
To view the videos you will need to download the free Real Player Download Real Player plugin for your browser - if you don't already have it. After installing Real Player, you can view the videos by clicking on one of these icons:
  • Click on this icon Hi Res - Cable/DSL if you have a cable or DSL connection.
  • Click on this iconLow Res - Modem if you have a Dial-up connection.
Below is the full course page which includes these videos:
2002 Changes to the NEC®
Article 680 Low Res - Modem Hi Res - Cable/DSL        Page 9 of 10
Swimming Pools, Fountains, And Similar Installations
680.26 Bonding
This section was revised to read:
(B) Bonding Together
(1) Metallic Parts of Pool Structure. All metallic parts of the water structure, including the reinforcing metal of the pool shell, coping stones, and deck, must be bonded to a common bonding grid [680.26(C)]. Steel tie-wires made-up tight is suitable for bonding reinforcing steel together. Where the reinforcing steel is encapsulated with a nonconductive compound, provisions must be made for an alternate means to eliminate voltage gradients, which would otherwise be provided by unencapsulated, bonded reinforcing steel. Figure 680-6
Intent: The revised text requires all reinforcing steel of the water structure to be bonded to a common bonding grid and any reinforcing steel that is encapsulated with a nonconductive compound must be provided with an alternate means to eliminate voltage gradients.
Author’s Comment: A task group has been assembled to investigate this issue and to provide data to the industry on how this could be accomplished since there is no acceptable method of bonding nonconductive-coated steel. Currently only steel without a nonconductive coating can be used for swimming pools, outdoor spas and hot tubs because there is no way to use steelstructural steel with nonconductive, anti-corrosion coatings to eliminate voltage gradients.
Figure 680–6
Click on Image to Enlarge
2002 NEC Changes Course - Part 2, Article 338 - Ch.9
This code changes program covers the changes to Article 338 through Chapter 9 of the 2002 NEC. Included is a video of one of Mike's most dynamic live classes with a fully illustrated, full-color textbook. The textbook contains over 150 diagrams which make the changes easy to understand. Includes textbook and 4.5-hr video.
Product Code: 02CCV2
MultiMedia: VHS Tape
Price: $109.00
NOTE: This course is also available in DVD format. Click here for details.
Table of Contents
Sample Pages
Sample Graphic
Copyright © 2004 Mike Holt Enterprises,Inc.
