Send to a Friend View / Add Comments
Some of you have completed our Online Continuing Education Courses which include video instruction and know this is a very fast way to obtain your CEU credits from the comfort of the chair you're sitting in. For the rest of you we are sending a weekly series of newsletters featuring an instructional page complete with videos.
To view the videos you will need to download the free Real Player Download Real Player plugin for your browser - if you don't already have it. After installing Real Player, you can view the videos by clicking on one of these icons:
  • Click on this icon Hi Res - Cable/DSL if you have a cable or DSL connection.
  • Click on this iconLow Res - Modem if you have a Dial-up connection.
Below is the full course page which includes these videos:
2002 Changes to the NEC®
Article 800 Low Res - Modem Hi Res - Cable/DSL        Page 3 of 5
Communication Circuits
800.6 Mechanical Execution of Work
The text to this section was revised to read:
Communications circuits must be installed in a neat and workmanlike manner. Cables installed exposed on the surface of ceilings and sidewalls must be supported by the structural components of the building in such a manner that the cable will not be damaged by normal building use. Such cables must be secured to structural components by straps, staples, hangers or similar fittings designed and installed so as not to damage the cable. Figure 800-1
Cables installed parallel to framing members must be protected against physical damage in accordance with 300.4(D). Figure 800-2
Intent: The revised text clarifies that cables must be properly secured and protected from physical damage.
Figure 800-1
Click on Image to Enlarge
Figure 800-2
2002 NEC Changes Course - Part 2, Article 338 - Ch.9
This code changes program covers the changes to Article 338 through Chapter 9 of the 2002 NEC. Included is a video of one of Mike's most dynamic live classes with a fully illustrated, full-color textbook. The textbook contains over 150 diagrams which make the changes easy to understand. Includes textbook and 4.5-hr video.
Product Code: 02CCV2
MultiMedia: VHS Tape
NOTE: This course is also available in DVD format. Click here for details.
Table of Contents
Sample Pages
Sample Graphic
Copyright © 2005 Mike Holt Enterprises,Inc.
