Send to a Friend View / Add Comments
HVAC Contractor and Employee Electrocuted in Crawlspace in North Carolina
Electrocution Fatality Investigation Reports
The following is a fatality investigation report of an incident where electrical incidents resulted in the death of a worker. This case was investigated by NIOSH.
HVAC Contractor and Employee Electrocuted in Crawlspace--North Carolina
FACE 94-17
SUMMARY
A 46-year-old male HVAC contractor and his 23-year-old employee (the victims) were electrocuted while installing air conditioning duct work in a crawlspace. The contractor and employee were installing a combination heating, ventilating, and air conditioning unit at a private residence. The employee was under a 38-inch-high crawlspace installing aluminum straps around the new duct work, using an electric drill to install screws through the straps. As the employee drilled a hole, the sharp edge of the strap contacted house wiring attached to a floor joist above him, damaging its insulation. This action allowed the drill bit and strap, which the employee was holding, to become energized. The current passed through the employee to ground, either through a cast iron sewer drain pipe or through cold water pipes in the immediate working area of the victim. The contractor, installing duct work in the attic, was summoned to the crawlspace by the residence owner, who had heard noise in the crawlspace. The contractor called into the crawl space for the employee, but did not receive an answer. The contractor entered the crawlspace and grabbed the victim while leaning against the same water pipe as the victim, allowing the current to flow through him to the ground. The owner of the residence pulled the main circuit breaker for the house and called 911. Police, fire, and emergency medical service personnel responded to the scene and, finding both men in cardiac arrest, initiated cardiopulmonary resuscitation. The victims were transported to the local hospital, where they were pronounced dead by the attending physician. NIOSH investigators determined that, in order to prevent similar incidents, employers should:
  • conduct a jobsite survey before starting any work to identify any hazards, implement appropriate control measures, and provide subsequent training to employees specific to all identified hazards
  • develop, implement and enforce a comprehensive written safety program
  • provide additional electrical safety training to those workers working with or around electrical current, including proper rescue procedures.
Full Report …
http://www.cdc.gov/niosh/face/in-house/full9417.html
[ View More Newsletters ]
Please Reply With Your Comments
12a. NEC Code Changes Textbook
Mike Holt’s Illustrated Changes to the NEC 2005 textbook is here! So, get ready now!
The 2005 NEC is here and its time to adapt. Don’t let the scale of this change intimidate you. With Mike Holt’s Illustrated Changes to the NEC 2005, you’ll be up-to-speed in no time. Nearly 5,000 changes were proposed for the 2005 NEC! Over 225 of them will have a significant impact on designing, installing and inspecting electrical systems. Mike takes you through these changes, which he considers to be of critical importance. You’ll be able to easily gauge how these changes will impact your work and apply them instantly. This 120-page comprehensive full-color textbook includes 198 color illustrations for reference. Subjects include: General Requirements, Circuits and Protection, Grounding versus Bonding, Wiring Methods, Equipment for General Use, Special Occupancies, Special Equipment, Special Conditions, and Limited Energy and Communications Systems.
Why does Mike’s book give you an edge? Because of the extra effort put forth to organize these changes in an easy-to-follow manner. Each change includes:
Cross references to related Code requirements help you understand how the Code rules relate to one another.
Background information for each change along with explanations, which are delivered in Mike’s trademark style… easy-to-understand.
Author’s Comments – These sections were written by Mike to help you better understand the NEC material, and to bring to your attention things he believes you should be aware of.
Full-color detailed graphics to reinforce those difficult concepts and provide instant understanding.
Product Code: 05BK
ISBN: 1-932685-27-8
Pages: 120
Illustrations: 198
View Ratings
Table of Contents
Sample Pages
Sample Graphic
  [ Back to Top ]
Copyright © 2005 Mike Holt Enterprises,Inc.
