Send to a Friend View / Add Comments
Some of you have completed our Online Continuing Education Courses which include video instruction. For the rest of you we are sending a weekly series of newsletters featuring an instructional page complete with videos.
To view the videos you will need to download the free Real Player Download Real Player plugin for your browser - if you don't already have it. After installing Real Player, you can view the videos by clicking one of the icons below:
  • Click on this icon Hi Res - Cable/DSL if you have a cable or DSL connection.
  • Click on this iconLow Res - Modem if you have a Dial-up connection.
Below is the full course page which includes these videos:
Article 408 (384 in 1999 NEC) Low Res - Modem Hi Res - Cable/DSL        Page 4 of 5
Switchboards and Panelboards
408.21 Grounded Conductor Terminations
Intent: This new section should ensure that grounded (neutral) conductors terminate within the panelboard to an individual terminal. This has been a UL requirement (UL Std. 67 – Panelboard Standard) for some time, and the addition to the NEC is intended to bring this information to the installers. Technically, this is covered by 110.3(B), which requires all equipment to be installed in accordance with the manufacturer's installation instructions and markings, but nobody knew it existed. UL Std. 67 (Panelboard Standard) permits up to three 10 AWG equipment grounding conductors to terminate on a single terminal, if the terminal is marked for this purpose. Figure 408-3
The intent of this requirement is to ensure that the grounded (neutral) conductor of a multiwire branch circuit is not momentarily disconnected, which could result in the destruction of electrical equipment and fires from overvoltage.
Figure 408–3
Click on Image to Enlarge
2002 NEC Changes Course - Part 2, Article 338 - Ch.9
This code changes program covers the changes to Article 338 through Chapter 9 of the 2002 NEC. Included is a video of one of Mike's most dynamic live classes with a fully illustrated, full-color textbook. The textbook contains over 150 diagrams which make the changes easy to understand. Includes textbook and 4.5-hr video.
Product Code: 02CCV2
MultiMedia: VHS Tape
NOTE: This course is also available in DVD format. Click here for details.
Table of Contents
Sample Pages
Sample Graphic
Copyright © 2004 Mike Holt Enterprises,Inc.
