Send
to a Friend |
View
/ Add Comments
In cooperation with the U.S. Consumer Product Safety Commission (CPSC), Fluke Corp. of Everett, Wash. is voluntarily recalling about 40,000 digital multimeters. About 17,200 were sold in the U.S. Multimeters are used to measure voltage, resistance and current. The recalled units can take longer than normal, up to 18 seconds, to display readings of AC voltages above 500 volts. Users can misinterpret the delayed reading to mean that high voltage is not present. If high voltage is present, users could be exposed to a risk of shock, electrocution and thermal burns. Fluke has received four reports from Canada and Australia in which users experienced a delayed response while measuring high voltage, though no injuries were reported. The recalled Fluke digital multimeters measure up to 1,000 volts alternating current (VAC) and direct current (VDC). "Fluke" and "175," "177" or "179" are written on the front of the unit. The tester body is yellow and black and measures about 7.25 inches long by 3.5 inches wide. Recalled units have a serial number below 79000000. The serial number is written on the back of the instrument under the hinged stand. Home and hardware stores and industrial distributors nationwide sold these testers from January 2001 through October 2001 for between $170 and $215. Consumers should stop using these testers immediately and contact Fluke for information on returning the recalled unit for a free repair. Consumers should call Fluke at 800-260-4819 between 8 a.m. and 7 p.m. ET Monday through Friday or go to Fluke's Web site at www.fluke.com/170recall. (08-19-02) |
| [ Back to Top ] |
