Send to a Friend View / Add Comments
Some of you have completed our Online Continuing Education Courses which include video instruction and know this is a very fast way to obtain your CEU credits from the comfort of the chair you're sitting in. For the rest of you we are sending a weekly series of newsletters featuring an instructional page complete with videos.
To view the videos you will need to download the free Real Player Download Real Player plugin for your browser - if you don't already have it. After installing Real Player, you can view the videos by clicking on one of these icons:
  • Click on this icon Hi Res - Cable/DSL if you have a cable or DSL connection.
  • Click on this iconLow Res - Modem if you have a Dial-up connection.
Below is the full course page which includes these videos:
2002 Changes to the NEC®
Article 680 Low Res - Modem Hi Res - Cable/DSL        Page 5 of 10
Swimming Pools, Fountains, And Similar Installations
680.12 Maintenance Disconnecting Means
The word “maintenance” was added to the heading and the text was revised to read:
One or more means to disconnect all ungrounded (hot) conductors must be provided for all utilization equipment other than lighting. Each means must be accessible and within sight (within 50 ft) from its equipment. Figure 680-3
Author’s Comment: See Article 100 for the definition of “in sight.”
Intent: This change clarifies that the maintenance disconnecting means does not apply to lighting equipment.
Author’s Comment: All disconnecting means are switches [Article 404] and switches must be located at least 5 ft. horizontally from the inside walls of a pool unless separated from the pool by a solid fence, wall, or other permanent barrier [680.22(C)].
Figure 680-3
Click on Image to Enlarge
Copyright © 2004 Mike Holt Enterprises,Inc.
