AF120 ARC-FAULT TESTER
Performs two tests with one installation!
  • Tests conventional or AFCI protected 120 VAC outlets for correct wiring.
  • Tests AFCI protected outlets to insure against trip at 30 mA (parallel arc and epd test).
  • Push button AFCI test.
  • High visibility lamps and easy-to-read attached chart enable convenient usage.
  • Small and light 3: x 1-3/8" x 1-3/8".
  • Patent pending.
  • Made in U.S.A.
For Details, visit http://www.etcon.com/etcon/newproducts.html
Copyright © 2002 Mike Holt Enterprises,Inc.
