Go to mikeholt.com
Home Electrical Protection Beyond the Code: Arc-Fault Circuit Interrupters
Jan 1st, 2001
ABSTRACT
The UL and CPSC concluded, in 1995, that circuit breakers able to trip when they detect either an arc or ground fault are ‘very promising’ in protecting against electrical fires. Subsequent development and testing by Eaton....Cutler-Hammer research engineers and others have clearly verified that conclusion, and, as a consequence, all of today’s AFCI circuit breakers, available from four manufacturers, protect against both arc and ground faults.
Ground fault protection is a “hidden” benefit; it is not required today by UL1699, the AFCI Standard. Nevertheless, Eaton....Cutler-Hammer has chosen to ‘dual-list’ its breakers to UL1699 and either UL1053, Ground-Fault Sensing or Relaying Equipment; or UL943, Ground-Fault Circuit Interrupter. This paper examines the process by which such ‘Dual-Listed’ breakers protect against the eleven recognized types of electrical wiring faults.
(HEAD) BACKGROUND: A STUDY IS THE FOUNDATION FOR SAFER RESIDENCES ...
Click Here to Download Complete Report [ PDF 247K ]
  [ Back to Top ]
Copyright © 2005 Mike Holt Enterprises,Inc.
