Some of you have completed our Online Continuing Education Courses which include video instruction. For the rest of you we are sending a weekly series of newsletters featuring an instructional page complete with videos.
To view the videos you will need to download the free Real Player Download Real Player plugin for your browser - if you don't already have it. After installing Real Player, you can view the videos by clicking one of the icons below:
  • Click on this icon Hi Res - Cable/DSL [5622Kb] if you have a cable or DSL connection.
  • Click on this iconLow Res - Modem [1695Kb] if you have a Dial-up connection.
Below is the full course page which includes these videos:
Article 240 Low Res - Modem [1695Kb] Hi Res - Cable/DSL [5622Kb]        Page 7 of 8
Overcurrent Protection
240.85 Applications
The second paragraph was revised and an FPN was added to read:
A circuit breaker with a straight voltage rating (240V or 480V) can be used on a circuit where the nominal voltage between any two conductors does not exceed the circuit breaker’s voltage rating. A 2-pole circuit breaker cannot be used for protecting a 3-phase, corner-grounded delta circuit unless the circuit breaker is marked 1 or 3-phase to indicate such suitability. Figure 240-5
A circuit breaker with a slash rating such as 120/240V or 480Y/277V can be used on a solidly-grounded circuit where the nominal voltage of any one conductor to ground does not exceed the lower of the two values and the nominal voltage between any two conductors does not exceed the higher value.
Figure 240-5
Click on Image to Enlarge
Copyright © 2003 Mike Holt Enterprises,Inc.
