Send to a Friend View / Add Comments
Some of you have completed our Online Continuing Education Courses which include video instruction. For the rest of you we are sending a weekly series of newsletters featuring an instructional page complete with videos.
To view the videos you will need to download the free Real Player Download Real Player plugin for your browser - if you don't already have it. After installing Real Player, you can view the videos by clicking on one of these icons:
  • Click on this icon Hi Res - Cable/DSL [5622Kb] if you have a cable or DSL connection.
  • Click on this iconLow Res - Modem [1695Kb] if you have a Dial-up connection.
Below is the full course page which includes these videos:
Article 376 (362 in 1999 NEC) Low Res - Modem [1695Kb] Hi Res - Cable/DSL [5622Kb]        Page 3 of 3
Metal Wireways
376.23 Wireway Sizing
This section was revised to read:
(B) Wireway Used as Pull Box. Where insulated conductors 4 AWG or larger are pulled through a wireway, the distance between raceway and cable entries enclosing the same conductor shall not be less than required by 314.28. Figure 376-2
Intent: This rule was revised to clarify that when a wireway is used as a pullbox for conductors 4 AWG and larger, it must be sized as a pullbox in accordance with 314.28 as follows:
Straight pulls, the minimum distance from where the conductors enter to the opposite wall must not be less than 8 times the trade size of the largest raceway 314.28(A)(1)].
Angle pulls, the distance from the raceway entry to the opposite wall must not be less than 6 times the trade diameter of the largest raceway, plus the sum of the diameters of the remaining raceways on the same wall and row [314.28(A)(2)].
U Pulls, when conductor enters and leaves from the same wall, the distance from where the raceways enter to the opposite wall must not be less than 6 times the trade diameter of the largest raceway, plus the sum of the diameters of the remaining raceways on the same wall and row [314.28(A)(2)].
The distance between raceways enclosing the same conductor shall not be less than 6 times the trade diameter of the largest raceway, measured from raceway edge to edge [314.28(A)(2)].
Figure 376-2
Click on Image to Enlarge
  [ Back to Top ]
Copyright © 2003 Mike Holt Enterprises,Inc.
