Send to a Friend View / Add Comments
Some of you have completed our Online Continuing Education Courses which include video instruction. For the rest of you we are sending a weekly series of newsletters featuring an instructional page complete with videos.
To view the videos you will need to download the free Real Player Download Real Player plugin for your browser - if you don't already have it. After installing Real Player, you can view the videos by clicking on one of these icons:
  • Click on this icon Hi Res - Cable/DSL [5622Kb] if you have a cable or DSL connection.
  • Click on this iconLow Res - Modem [1695Kb] if you have a Dial-up connection.
Below is the full course page which includes these videos:
Article 400 Low Res - Modem [1695Kb] Hi Res - Cable/DSL [5622Kb]        Page 3 of 4
Flexible Cords and Cables
400.7 Uses Permitted
The word “stationary” was replaced with “utilization.” The subsection was revised to read:
(A) Uses Permitted. Flexible cords and cables must be used only for:
(1) Pendants
(2) Wiring of luminaires
(3) Connection of portable lamps, portable and mobile signs, or appliances
(4) Elevator cables
(5) Wiring of cranes and hoists
(6) Connection of stationary utilization equipment to facilitate frequent interchange.
Figure 400-1
(7) Prevention of the transmission of noise or vibration
(8) Appliances where the fastening means and mechanical connections are specifically designed to permit ready removal for maintenance and repair, and the appliance is intended or identified for flexible cord connections
(9) Data processing cables as permitted by 645.5
(10) Connection of moving parts
(11) Temporary wiring as permitted in Sections 527.4(B) and 527.4(C)
Intent: The revised text is intended to clarify that flexible cords can be used for any utilization equipment to facilitate frequent interchange, whether or not the equipment is stationary.
Figure 400-1
Click on Image to Enlarge
  [ Back to Top ]
Copyright © 2003 Mike Holt Enterprises,Inc.
