Send to a Friend View / Add Comments
Some of you have completed our Online Continuing Education Courses which include video instruction. For the rest of you we are sending a weekly series of newsletters featuring an instructional page complete with videos.
To view the videos you will need to download the free Real Player Download Real Player plugin for your browser - if you don't already have it. After installing Real Player, you can view the videos by clicking on one of these icons:
  • Click on this icon Hi Res - Cable/DSL if you have a cable or DSL connection.
  • Click on this iconLow Res - Modem if you have a Dial-up connection.
Below is the full course page which includes these videos:
Article 440 Low Res - Modem Hi Res - Cable/DSL        Page 2 of 2
Air-Conditioning and Refrigerating Equipment
440.14 Location
A sentence was added to this section so that it now reads:
Disconnecting means must be located within sight (within 50 ft) from and readily accessible from the air-conditioning or refrigerating equipment. The disconnecting means can be installed on or within the air-conditioning or refrigerating equipment. Figure 440-1
Author’s Comment: See Article 100 for the definition of “in sight”.
The disconnecting means cannot be located on panels that are designed to allow access to the air-conditioning or refrigeration equipment. Figure 440-2
Intent: Problems have been encountered in the field where the disconnecting means was installed on the access panels of A/C and refrigeration equipment. This rule should take care of that problem.
Figure 440–1
Click on Image to Enlarge
Figure 440–2
Copyright © 2004 Mike Holt Enterprises,Inc.
