Send to a Friend View / Add Comments
Some of you have completed our Online Continuing Education Courses which include video instruction and know this is a very fast way to obtain your CEU credits from the comfort of the chair you're sitting in. For the rest of you we are sending a weekly series of newsletters featuring an instructional page complete with videos.
To view the videos you will need to download the free Real Player Download Real Player plugin for your browser - if you don't already have it. After installing Real Player, you can view the videos by clicking on one of these icons:
  • Click on this icon Hi Res - Cable/DSL if you have a cable or DSL connection.
  • Click on this iconLow Res - Modem if you have a Dial-up connection.
Below is the full course page which includes these videos:
2002 Changes to the NEC®
Article 680 Low Res - Modem Hi Res - Cable/DSL        Page 8 of 9
Swimming Pools, Fountains, And Similar Installations
680.22 Area Lighting, Receptacles, and Equipment
Subsection revised to read:
(C) Switching Devices. Switching devices must be located at least 5 ft. horizontally from the inside walls of a pool unless separated from the pool by a solid fence, wall, or other permanent barrier. Alternatively, a switch that is listed as being acceptable for use within 5 ft. is permitted.
Intent: The revised text allows pneumatic switches (i.e. nonelectric) that are listed for this purpose to be within 5 ft. of the water.
Copyright © 2004 Mike Holt Enterprises,Inc.
