Send to a Friend View / Add Comments
Some of you have completed our Online Continuing Education Courses which include video instruction and know this is a very fast way to obtain your CEU credits from the comfort of the chair you're sitting in. For the rest of you we are sending a weekly series of newsletters featuring an instructional page complete with videos.
To view the videos you will need to download the free Real Player Download Real Player plugin for your browser - if you don't already have it. After installing Real Player, you can view the videos by clicking on one of these icons:
  • Click on this icon Hi Res - Cable/DSL if you have a cable or DSL connection.
  • Click on this iconLow Res - Modem if you have a Dial-up connection.
Below is the full course page which includes these videos:
2002 Changes to the NEC®
Article 690 Low Res - Modem Hi Res - Cable/DSL        Page 2 of 3
Solar Photovoltaic Systems
690.14 Additional Provisions
A new subsection was added and it reads:
(C) Requirements for Disconnecting Means. AMeans must be provided to disconnect all conductors in a building or other structure from the photovoltaic system conductors in accordance with the following: Figure 690-2
(1) Location. The photovoltaic disconnecting means must be installed at a readily accessible location either outside of a building or structure or inside nearest the point of entrance of the system conductors. The photovoltaic system disconnecting means cannot be installed in bathrooms.
(2) Marking. Each photovoltaic system disconnecting means must be permanently marked to identify it as a photovoltaic system disconnect.
(3) Suitable for Use. Each photovoltaic system disconnecting means must be suitable for the prevailing conditions. Equipment installed in hazardous (classified) locations must comply with the requirements of Articles 500 through 517.
(4) Maximum Number of Disconnects. The photovoltaic system disconnecting means must consist of not more than six switches or six circuit breakers mounted in a single enclosure, in a group of separate enclosures, or in or on a switchboard.
Intent: The new subsection clarifies that the disconnecting means for the PV system must comply with similar requirements contained in Article 230 for services.
Figure 690 -2
Click on Image to Enlarge
Copyright © 2004 Mike Holt Enterprises,Inc.
