Send to a Friend View / Add Comments
Revisions to the 2005 NEC
70-05 SB First Printing NFPA 70
70-05 LL First Printing Revisions for Print Version of NEC
Errata
NFPA 70
National Electrical Code®
2005 Edition
Reference: 2005 NEC ®
The National Electrical Code Correlating Committee notes the following errors in the 2005 edition of
NFPA 70, National Electrical Code.
How to Use this Errata Sheet
This is a list of errata to the first printing of the 2005 NEC ® . A first printing is indicated by the numeral 1
as the last digit in the line of number appearing at the bottom of the inside front cover.
1. Page 70-36 110.26(A)(1): Revise reference to “Table 110.26(A)(1)(1)” to read “Table 110.26(A)(1)”.
2. Page 70-47 210.8(A): Relocate text appearing at bottom of left-hand column that reads “Receptacles installed under the exceptions to 210.8(A)(5) shall not be considered as meeting the requirements of 210.52(G)” to the right-hand column following Exception No. 3 to 210.8(A)(5).
3. Page 70-59 220.14(K): Revise reference “220.14” to “220.14(I)” ...
4. Page 70-73 230.24(A): Revise fourth exception to “Exception No. 4”.
5. Page 70-78 230.72(B): First sentence, revise word “ore” to “more”.
6. Page 70-91 240.93 First paragraph & 240.93(A), (B), (C): Delete entire text.
7. Page 70-126 300.6(A): First sentence, revise “listed” to “approved”.
8. Page 70-139 Table 310.13: Underground service entrance cable – single conductor, revise thickness of insulation “mils” column from 5 to 45
9. Page 70-150 Table 310.64: 25,001 to 28,000 volts, 1 AWG and 1/0AWG – 2000 kcmil, 100% insulation level, revise 2.80 mils to 280 mils.
10. Page 70-174 Table 326.80: Revise amperes value for 1750 kcmil from 344 to 315
11. Page 70-176 330.10(B): Revise 770.52 to 770.133.
12. Page 70-182 336.104(C): Revise Class I to Class 1.
13. Page 70-363 502.150(A)(1): Revise 502.100(A) to 502.10(A).14. Page 70-374 505.9(B)(1) Listing.: Revise second sentence, “Equipment that is listed of for a Zone 1 location shall be permitted in a Zone 2 location of the same gas or vapor, provided that it is installed in accordance with the requirements for the marked type of protection.”
15. Page 70-386
506.9(D) Exception No.2: Revise “500.6(D) and Table 500.6(D)” to “500.8(B) and Table 500.8(B)”.
16. Page 70-444 547.9(A)(2): Revise 230.24(A) to 230.24.
17. Page 70-584 760.8: Add new Fine Print Note to read, “FPN: One source of information describing industry practices is ANSI/NECA 305-2001, Standard for Fire Alarm System Job Practice.”
18. Page 70-590 760.81(C) FPN: Revise second sentence, “Similarly, one method of defining fire-resistant cables is be by establishing a maximum allowable flame travel distance of 1.52 m (5 ft) when tested in accordance with the same test.
19. Page 70-591 Table 760.81(G): Revise 760.31 to 760.81 in three references.
20. Page 70-595 770.179(A): Revise title “Types OFND and OFCD” to “Types OFNP and OFCP.”
21. Page 70-613 Table 820.113: Revise reference for CATVX from “820.179(D) and 820.154(C)” to “820.179(D) and 820.154(D)”
22. Page 70-626 Chapter 9, Table 4, Article 362 – Electrical Nonmetallic Tubing (ENT): Add Trade Size “2” in second column.
23. Page 70-717 Example D1(a): Under “Minimum Feeder Size” revise “Range (see Table 220.19)” to “Range (see Table 220.55)”.
24. Page 70-722 Example D4(b): Under “Feeder Neutral Load for Feeder from Service Equipment to Meter Bank (For 20 Dwelling Units) revise “[see Table 220.55 and Table 220.61(B)]” to “[see Table 220.55 and 220.61(B)]”.
25. Page 70-681 Table C.5: Revise table heading from “CONDUCTORS” to “FIXTURE WIRES”
26. Page 70-686 Table C.6: Revise table heading from “CONDUCTORS” to “FIXTURE WIRES”
27. Page 70-726 Annex E – Types of Construction: Second paragraph, fourth sentence, revise “Type 1” to “Type I”.
Issue Date: December 24, 2004
Copyright © 2004 All Rights Reserved
NATIONAL FIRE PROTECTION ASSOCIATION
NEC Spiral Edition Code Book
This spiral edition makes the code book much easier to use. The spiral coil allows you to conveniently study by placing the book folded on your desk. It lays flat and you can even put it na hook in your truck. The most widely adopted element of a building code in the United States and the world, the NEC® is the benchmark for safe and efficient electrical installations. Whether your jurisdiction adopts the 2005 Code immediately or down the road, you need to extend your knowledge and take advantage of the benefits right away, not months or years behind your peers in the electrical industry. NFPA product.
Product Code: 05SB
  [ Back to Top ]
Copyright © 2004 Mike Holt Enterprises,Inc.
