Send to a Friend View / Add Comments
Use of Anti Short Bushings for Terminating Type MC Cable
Dear Mike,
In the past I have emailed you questions on the code and your responses are most respected in the field. I am quite disturbed by the NEC's lack of clarification of the usage of anti-short bushings, AKA "Redheads," in the application of MC cable installations. I have seen that the NEC only addresses its usage in AC cable and does not apply it to MC cable.
Common sense is to use them with all armor cable installations. I have personally had applications blow up in my hand when people do not use them. I am an advocate of its usage and strictly monitor my apprentices.
I do truly wish for some clarification and strict correction in the NEC. I also have argued the fact that the bushings installed in "speed lock" and "push in" connectors is to protect the wire from the connector only and DOES NOT replace the anti-short bushing that protects the wire from the armor cable sheath.
I await your response and do hope that it is addressed in the EC&M magazine as it is regarded as clarification to Code and read for corrections.
Thank you Kindly Sir
Englewood, CO
Mike Holt's Response: Derek, I can understand your frustration, but this issue has been clearly address by the NEMA Engineering Department Bulletin No. 90, titled Use of Anti-Short Bushings for Terminating Type MC Cable.
ROP #7-116 from the May 2001 Report on Proposals (ROP) for the 2002 NEC was a proposal seeking to require anti-short bushings on all MC Cable termination installations. The following is an excerpt from the Panel statement rejecting the proposal:
Anti-short bushings are not required for Type MC cable in accordance with the listing for the product. The termination fittings approved for use with Type MC cables are designed such that the wires will not come in contact with the cut edge of the armor; the throat of the fitting is small enough to prevent contact with the armor. Type MC termination fittings perform the same function for Type MC cable as Type AC terminations plus the anti-short bushing do for Type AC cable.
Click here to download the entire bulletin.
[ View More Newsletters ] View / Add Comments
21. National Electrical Code Library DVDs
If you want to really understand the NEC, this NEC Library is for you. Mike explains, in great detail, the history of the rule, the reason for the rule and how to apply the Code for everyday use. This program explains the 2005 Code, how to use the NEC, general installation requirements, branch circuits, feeders, services and overcurrent protection, grounding versus bonding, conductors, cables and raceways, boxes, panels, motors and transformers, and more.
Understanding the NEC Volumes 1 & 2 were written to provide insight into, and an understanding of, many of the technical rules of the NEC. These books contain clear graphics and examples. The National Electrical Code Library includes Understanding the NEC Volumes 1 & 2, the NEC Practice Questions book and 10 DVD's. Save over $600 by purchasing this library.
Product Code: 05DECODVD
MultiMedia: DVD
DVD/CD Return Policy: Unopened sealed DVD's or CD's may be returned within 10 days and we will credit your credit card or issue a refund for the price of the item(s). Opened items may not be returned unless they arrive defective.
  [ Back to Top ]
Copyright © 2005 Mike Holt Enterprises,Inc.
